AURIX™ Forum Discussions
I am working on a TC234.
My software, which is based on Autosar is doing some checks in ROM at startup.
The address range X which is checked is not written during flashing my software.
That means, that I have reserved this address range X in my linker script.
The software expects that this address range X in ROM is already filled with correct data.
This means before flashing my software, another HEX file is flashed, which fills this address range X.
Best case:
1)The address range X is written.
2lAfter that my software is flashed.
3)My software runs and accesses this memory.
4) everything is fine
Worst case:
1) The address range X is unwritten (by a mistake)
2) my software is flashed
3) my software runs and accesses this memory
4) A trap occurs while accessing unwritten memory
How do I check safely if the address range X is unwritten?
User11926
Dear Mr. Ferhat,
I am also having problem with the ROM check.
During ROM check i am getting trap while accessing the uninitialized data.
If you know how to initialize the ROM during flashing please tell me ,it would be helpful to me.
Thank you
Venkat
