03:49 AM
Jan 01, 2015
03:49 AM
Hello All,
I would like to ask for support for the below issue facing with the environment as mentioned below.
Working Environment:
controller- TC277TE
Compiler- Tasking 4.0r2
Debugger- trace32
Requirement: To create a build which should have all code at desired location (not default location) except jump instruction at RESET location.
Issue: Here I am using library for some functionality like- _c_init().But for this library code, I am not able to change the code location to desired location.
Here for your reference, i have attached the source files, LSL file, compiler, linker and map files. Please let us know how can I resolve the issue.
Dharmik B
controller- TC277TE
Debugger- trace32
Dharmik B
01:28 PM
Jan 02, 2015
01:28 PM
_c_init() function is for the initialisation of the assigned global variables which is in the start-up file(cstart.c). And if u want to change your code segment in some other location then u can do it in LSL file by changing the address location of the text segment(PFlash).For this you also need to the check type of bus access to the memory.
09:24 AM
Jan 03, 2015
09:24 AM
Thank you for your response. By using lsl file, I am able to change code location for cstart.c and application.c, but I am not able to change for library, which is used from the available compiler library files. Do I have any option to change for application?
07:42 AM
Mar 18, 2015
07:42 AM
Hello Dharmik,
of course you are able to change code location for every symbol, even the ones supplied by the compiler.
Just add an select ".text._c_init*"; to your group if you want to change the c_init() location.
