Hi there,
I wonder if everyone has my same problem or has resolve it. I implemented on TC375 a CAN communication - I set the can module on TC375 as a receiver one. My aim is to obtain, for every received message, the timestamp of the message itself.
I thought to associeted, every time the interrupt routine of received message was triggered, a subroutine which use STM0_TIM0 register, but i have some problems, the number obtained it's not easily understandable.
There are other ways to extract time stamp of messages on CAN bus communication for TC375?
A specific library for example or similar?
Thank you so much!
I make a recap in order to verify i really understand:
I initialize the stucture _Ifx_Can_RxMsg, then I do the same with the interrupt
IfxCan_Node_getDataLengthCode
and in this way i get the time stamp of the arrived message.
I have a question: if i initialize the structure and than every time i call the interrupt of received message i use as and example:
readCanMsg(...);
msgID = rxMsg.messageId;
time_stamp =
(IfxCan_DataLengthCode)rxBufferElement->R1.B.DLC;
Can I do this, right?
On start of frame reception / transmission the counter value is captured and stored into the timestamp section
of an Rx Buffer / Rx FIFO (RXTS[15:0]) or Tx Event FIFO (TXTS[15:0]) element.
You can check the RX Buffer for timestamp. Do you have any question on this?
Hi!
thank you so much for the answer. So yes, I have some question about:
I initialize Rx Buffer (or Tx Buffer) during the configuration of MCAN, my question is which command can I use to log into Buffers?
I try to explain myself better:
There is a kind of structure in which I can extract an attribute?
or do I need to use more specific command to log into?
thank you so much for patience
Please check below struct for R1.
IFX_INLINE uint32 IfxCan_Node_getDataLengthCode(Ifx_CAN_RXMSG *rxBufferElement)
return (IfxCan_DataLengthCode)rxBufferElement->R1.B.DLC;
Above call is for your reference. You should modify as your request.
Thank you so much!
readCanMsg(...);
time_stamp =
Hi Sara, Yes you can do this, please note that DLC is not timestamp, you should modify the code.
Oh, sorry, how silly!
So maybe I didn't get which available variable the time information was stored?
Referring to my "pseudo code" : time_stamp will be equal to what?
I can't get it
thank you so much for your patience
typedef struct _Ifx_CAN_R1_Bits
Ifx_UReg_32Bit RXTS:16; /**< \brief [15:0] Rx Timestamp (rwh) */
Ifx_UReg_32Bit DLC:4; /**< \brief [19:16] Data Length Code (rwh) */
Ifx_UReg_32Bit BRS:1; /**< \brief [20:20] Bit Rate Switch (rwh) */
Ifx_UReg_32Bit FDF:1; /**< \brief [21:21] Frame Data Format (rwh) */
Ifx_UReg_32Bit reserved_22:2; /**< \brief [23:22] \internal Reserved */
Ifx_UReg_32Bit FIDX:7; /**< \brief [30:24] Filter Index (rwh) */
Ifx_UReg_32Bit ANMF:1; /**< \brief [31:31] Accepted Non-matching Frame (rwh) */
} Ifx_CAN_R1_Bits;
Really thank you!
Your replay will be extraordinary useful!
