AURIX™ Forum Discussions
rohitk
I am trying to deploy sample LED blinking code on Triboard TC389. But when debugging problem occurs: 'Error creating session' with description:
The debug instrument could not be initialized. Please consult the below error message.
The shared library mcdxdas.dll cannot be found or is inaccessible.'
I looked up online and I found that the dll file is part of the DAS which already installed.
Thanks in advance for any help!
dw
Dear rohitk,
Could you please try to re-install the DAS, if you are using ADS, please try reinstall it also. Below is the link:
https://www.infineon.com/cms/en/product/promopages/das/?redirId=53841
After installation, mcdxdas.dll is in below path:
dw
dw
Dear rohitk,
dw
