robs1
Level 4
Level 4
100 sign-ins 50 replies posted First solution authored
How can I set the CMU clock 0 (for ATOM) to 200 MHz??
My code lines doesn't work.
Can you help me?
Jeremy_Z
250 sign-ins 100 likes received 750 replies posted
Hi @robs1
Please check the below condition is met before configuring the CLS0_CLK_DIV bits.
BR,
Jeremy
Jeremy_Z
Hi @robs1
Please check the code to ensure the CLS0_CLK runs at 200 MHz.
BR,
Jeremy
robs1
Level 4
Level 4
Hi, thank you!
How can I set this clock to 200 MHz? By which line of code
Jeremy_Z
Hi @robs1
Firstly, I'd like to suggest you acquire the frequency of the CLS0_CLK by using the below IfxGtm_getClusterFrequency() function, then it can provide the clues to adjust its frequency.
It doesn't exist such a function that can set the CLS0_CLK to an expected frequency in one action.
float32 IfxGtm_getClusterFrequency(Ifx_GTM *gtm, IfxGtm_Cluster cluster)
    float32 Freq;
    uint8   clsDiv = ((gtm->CLS_CLK_CFG.U) >> (cluster * 2)) & 0x3;
    if (clsDiv == 0)
        Freq = 0.0; /* cluster is disabled - return 0 */
    else
        Freq = IfxGtm_getSysClkFrequency() / clsDiv;
    return Freq;
BR,
Jeremy
robs1
Level 4
Level 4
Yes, I found that its value is 100 MHz, so I need to set it to 200 MHz but adding this
gtm_ptr->CLS_CLK_CFG.B.CLS0_CLK_DIV=1;
the code doesn't run.
Jeremy_Z
Hi @robs1 ,
Yes, setting the CLS0_CLK_DIV bits = 01 should work.
And I don't know the meaning of 'the code doesn't run'.
BR,
Jeremy
robs1
Level 4
Level 4
gtm_ptr->CMU.GCLK_NUM.B.GCLK_NUM = 0x1;
gtm_ptr->CMU.GCLK_NUM.B.GCLK_NUM = 0x1; // write twice to be sure, taken from specs
gtm_ptr->CMU.GCLK_DEN.B.GCLK_DEN = 1;
gtm_ptr->CMU.CLK[0].CTRL.B.CLK_CNT = 0;
gtm_ptr->CMU.CLK_EN.B.EN_CLK0 = 0x2;
I wrote like this but the code can’t be uploaded in the board so it is “suspended” at the second code line
Jeremy_Z
Hi @robs1
BR,
Jeremy
robs1
Level 4
Level 4
Thank you , now it works!
robs1
Level 4
Level 4
gtm_ptr->CTRL.B.RF_PROT=0;
gtm_ptr->CLS_CLK_CFG.B.CLS0_CLK_DIV=01;
I wrote like this, now the code is upload successfully but when I check with:
clockff=IfxGtm_Cmu_getClkFrequency(&MODULE_GTM, IfxGtm_Cmu_Clk_0, TRUE);
I obtain a clockff of 100 MHz still.... where am I wrong?
