Oct 30, 2018
10:24 PM
Oct 30, 2018
10:24 PM
I am using VADC to convert A to D but result register always 0 while debugging, But in result register VF flag getting update. I am using VADC example code from AURIX library. Queue status register showing Queue is empty.
02:01 AM
Nov 27, 2018
02:01 AM
I would say you forgot to enable the analog part of the VADC group you are using. Check bit field ANONS/ANONC of register GxARBCFG.
Jan 13, 2019
09:25 AM
Jan 13, 2019
09:25 AM
Thank you for your reply. We already enabled that ANONC bit. The problem is we got the code for TC27x C step microcontroller, but ours is TC277 B step. VADC Configuration is different for both, That's why conversion not happened. Now we found the solution.
Nov 19, 2019
05:00 AM
Nov 19, 2019
05:00 AM
Hello narayanan,
You can try the new code example project for the VADC module here: VADC training code example.
this example also comes with a tutorial, which can be found here: VADC tutorial.
Furthermore, if you are interested in other modules and you want to start programming for AURIX™, you can get the new Integrated Development Environment (IDE) here: AURIX™ Development Studio and get inspired by numerous trainings from here: AURIX™ Trainings.
If you are not familiar with Eclipse based IDE’s checkout the Getting Started guide!
Hope it helps,
teoBits
Hope it helps,
teoBits
