Apr 24, 2019
10:41 PM
Apr 24, 2019
10:41 PM
Hello All,
I am using AURIX TC275 controller.
Please tell me about "25.22.2.2 GTM to Port Control Registers" of "Infineon-TC27x_D-step-UM-v02_02-EN.pdf".
There is TOUTSELn to select "Output Timer Mapped(Table 25-68 GTM to Port Mapping)".
Where are Registers to select "Input Timer Mapped(Table 25-68 GTM to Port Mapping)".
Thanks in advance.
Thanks in advance.
03:24 PM
Apr 25, 2019
03:24 PM
Have you looked at section "25.22.2.1 Port to GTM Control Registers"? Then for what is available at the TIMx look at Table 25-7x.
Apr 25, 2019
07:01 PM
Apr 25, 2019
07:01 PM
Thank you for quick reply.
I've looked at section "25.22.2.1 Port to GTM" and used to select for TIMnINSEL.
Is "Input Timer Mapped(Table 25-68 GTM to Port Mapping)" invalid ?
I want to confirm that I can connect Port.Channel to TIMn_ch by only configuration TIMnINSEL.
