- Email to a Friend
Hi ,
Below error showing in V6.3r1 in linker file, but same Linker file can build successfully in V6.2r2. let me know if any changes required in linker file to build in V6.3r1.
ToolEnv\0_Build\1_Config\Config_Tricore_Tasking\Lcf_Tasking_Tricore_Tc.lsl" 844/18] LSL unexpected error: could not find heap section heap
ltc F019: unrecoverable error: fatal locate error
amk E452: ["makefile" 119/0] target 'Application.elf' returned exit code 1
amk E451: make stopped
Thanks and Regards
Nazeem.
- Email to a Friend
You need to create heap section in your linker file. The error is about missing heap section
section_setup :vtc:linear
my_heap "my_heap" (min_size = (1K), fixed, align = 8);
- Email to a Friend
