AURIX™ Forum Discussions
Ilan
We use TSIM to simulate Tricore TC399, can we use TSIM to simulate multicore application?
We try to simulate a simple application that run on multiple core (runs on board), But using TSIM it does not seems to work.
From the user manual we understand that probably TSIM is not supporting multicore but may run a chosen core using CORE_ID. Is it correct?
Nambi
First like given 25 likes received 50 solutions authored
Yes. Based on the user guide, TSIM is not currently multi-core capable.
Best Regards.
Nambi
1. Could you refer to the below thread?
https://community.infineon.com/t5/AURIX/TSIM-simulator/m-p/319671
2. Could you share the link to the TSIM simulator?
Best Regards.
Ilan
We have got it as part of the hightec toolchain. You can find the tool and the doc it in the hightec toolchain directory under bin and doc directory
Nambi
Does this thread answer your questions?
Best Regards.
Ilan
No, this thread do not talk about multicore support.
From what I understood TSIM simulator do not support multi core
Nambi
Best Regards.
