Apr 01, 2022
04:38 AM
Apr 01, 2022
04:38 AM
- I have configured TOM to generate the PWM. Is there any register that notifies about the rising or the falling edge of the PWM in the TC297 Aurix Controller.
- Also, Please let me know if there is any possibility to trigger ADC with the PWM generated.
- if yes, how can we do it..?
Thanks in advance.
Anusha.K
Labels
AURIX
- tc297
03:57 AM
Apr 12, 2022
03:57 AM
Hi Anusha,
maybe you can go with the Input Output Monitor (IOM). There you can compare incoming or outgoing signals with a reference signal. You could do it also the old way looping signal into another GPIO and define an interrupt for falling or rising edges. I assume you will be sure about whether the signal is generated rather having some register information?
In case of the ADC question, please provide more detail. What exactly do you wanna trigger here?
TBencher
Apr 12, 2022
04:00 AM
Apr 12, 2022
04:00 AM
Regarding GTM, there could be also other possibilities to connect outputs with inputs... BOSCH has a very good documentation on that, which should also be part of the UM.
TBencher
