- Email to a Friend
Customer plan adopt TLE9255 at Linux OS, and need to conform SocketCAN.
Have you any available resource getting started?
Regard,
Kevin
- Email to a Friend
Hi KeTs,
TLE9255 is CAN Transceiver, not CAN controller, means MCU/MPU need connect a CAN controller to control transceiver to send and receive data with CAN net.
Looks like QCS610 don't integrate a CAN controller, so a SPI interface needed to connect CAN controller in your design.
Thanks, Kevin
- Email to a Friend
Could you elaborate a little bit more on the requirement? How would you adopt TLE9255 at Linux OS? what's the host MCU?
- Email to a Friend
Hi Roy,
Thanks of your reply.
Adopt QCS610 chip , add CAN bus interface and and need to conform SocketCAN.
Regard,
Kevin
- Email to a Friend
Hi KeTs,
If use Qualcomm QCS610 and QCS410 Application Processors and linux OS, please refer to TLE9255 datasheet and other documents as below:
dw
- Email to a Friend
Hi DW,
I just see DS , did not see other driver and document.
Could you describe us more specifically in detail?
Regard,
Kevin
- Email to a Friend
Hi KeTs,
There is an application note at below link:
dw
- Email to a Friend
Hi KeTs,
Thanks, Kevin
- Email to a Friend
Hi Kevin Wu,
Got it, thanks of your reply.
Kevin Tsai
