TLE9255 Linux driver
KeTs_2342536
Distributor - Arrow(GC)
First like given 50 sign-ins First comment on blog
Customer plan adopt TLE9255 at Linux OS, and need to conform SocketCAN.
Have you any available resource getting started?
Regard,
Kevin
Kevin_Wu
50 solutions authored 100 sign-ins 50 replies posted
Hi KeTs,
 TLE9255 is CAN Transceiver, not CAN controller, means MCU/MPU need connect a CAN controller to control transceiver to send and receive data with CAN net.
  Looks like QCS610 don't integrate a CAN controller, so a SPI interface needed to connect CAN controller in your design.
Thanks, Kevin
Roy_Liu
5 comments on KBA First comment on KBA 10 questions asked
Could you elaborate a little bit more on the requirement? How would you adopt TLE9255 at Linux OS? what's the host MCU?
Roy Liu
KeTs_2342536
Hi Roy,
Thanks of your reply.
Adopt QCS610 chip , add CAN bus interface and and need to conform SocketCAN.
Regard,
Kevin
Di_W
Hi KeTs,
If use Qualcomm QCS610 and QCS410 Application Processors and linux OS, please refer to TLE9255 datasheet and other documents as below:
https://www.infineon.com/cms/en/product/transceivers/automotive-transceiver/automotive-can-transceiv...
dw
KeTs_2342536
Hi DW,
I just see DS ,  did not see other driver and document.
Could you describe us more specifically in detail?
Regard,
Kevin
Di_W
Kevin_Wu
Hi KeTs,
Thanks, Kevin
KeTs_2342536
Hi Kevin Wu,
Got it, thanks of your reply.
Kevin Tsai
