- Email to a Friend
- Email to a Friend
Yes, this can be supported by setting TIM[i]_CH[x]_CTRL.ISL to detect both the edges and configure GPRx_SEL/ EGPRx_SEL to store the TBU (timestamp) to GPRx.
- Email to a Friend
The solution is not working. Added my implementation and output in detail could you pls have a look
I am trying to measure the duty cycle of the waveform with the time difference between rising and falling edge timstamp. The waveform has a period of 100 us and on time of 56 us.
Implementation
We read the var diff which subtracts the previous and current timestamp measurement from GPR1 reg. This func is being called by master trigger pulse every 100 us
FS_Ph_Timestamp_prev = FS_Ph_Timestamp_current;
FS_Ph_Timestamp_current = (float)((GTM_Module_Ptr_temp->TIM[3].CH2.GPR1.B.GPR1)* 0.00000001);
diff = FS_Ph_Timestamp_prev - FS_Ph_Timestamp_current;
O/P from above suggested configuration
Kumaresh
