May 01, 2020
09:55 AM
May 01, 2020
09:55 AM
Hi everyone,
I'm starting to work with the AURIX TFT 397A kit (i'm kinda new in this). I'm following the Migrate iLLD demos to managed HighTec projects
and i've found a problem while debugging the board.
This problem only occur when i try to debug the demo with the iLLD. When i try to debug an example from HighTec i found no problem at all.
i'll appreciate any help about this subject!
Thank you all
Thank you all
03:25 AM
May 14, 2021
03:25 AM
It's target select problem.
You can click the "Change..." button for TC397A device.
