Oct 29, 2019
04:23 AM
Oct 29, 2019
04:23 AM
Oct 30, 2019
03:17 AM
Oct 30, 2019
03:17 AM
This is not explainable with some words. Please check the UM for more information especially chapter 1.5 Software over the Air (SOTA)
Dec 11, 2019
10:28 PM
Dec 11, 2019
10:28 PM
I have studied the UM ch.1.5 on SOTA, where the swapping mechanism is unclear.
Jan 31, 2020
03:24 AM
Jan 31, 2020
03:24 AM
Check the Application Note AP32404 from your myicp account. This helps to understand the feature. If you can't find the AppNote then ask your Infineon contact to get complete access.
Feb 03, 2020
09:30 AM
Feb 03, 2020
09:30 AM
Hello Support,
Please provide me the full title of AP32404 Application Note so that I can ask Infineon FAE for myicp update.
Best Regards
Best Regards
Feb 11, 2020
12:09 AM
Feb 11, 2020
12:09 AM
The complete title is:
AP32404-Tutorial_Using_the_2nd_Generation_AURIX_SWAP_mechanism_for_SW_updates_Over_The_Air_v1.1.pdf
You need access to folder 10 AURIX TC3xx HSM, check with your Infineon FAE what you must do to get access to this folder or how you can get the AppNote.
Sep 21, 2020
04:38 AM
Sep 21, 2020
04:38 AM
Where should i find this document? Can i get a link?
Oct 22, 2020
06:38 AM
Oct 22, 2020
06:38 AM
Hi all,
I tried to get information about "how to configure dualbank SWAP aurix 2g".
There are a lot of information in the Aurix documentation "AURIXTC3XX_um_part1_V1.0.0.pdf" but this is not enough.
I created several .hex files to modify ucb_bmh0 /ucb_swap and ucb_otp0 but it seems that bytes value are not well configured.
I ask for access to the related document :
AP32404-Tutorial_Using_the_2nd_Generation_AURIX_SWAP_mecha nism_for_SW_updates_Over_The_Air_v1.1.pdf
Normally it must be in the folder : 10 AURIX TC3xx HSM in myicp account …
If anybody got information : how to configure ucbs for dualbank swap ? or how to have access to this document ?
01:52 AM
Oct 23, 2020
01:52 AM
I use the 4.7 version of Memtool and SWAP options are not avalables for TriBoard_TC38xA configuration.
Do you have a Memtool version which allow to configure SWAP feature on UCBs ?
Thank you in advance.
