AURIX™ Forum Discussions
enrico_b
First like given 10 sign-ins 5 solutions authored
Customer would like to locate an application in RAM only, and run program from RAM only without using Flash using ADS 1.5.0
enrico_b
You can set any option from the "Expert Settings" field of a certain tool.
  1. Click on "Active Project Properties" in the toolbar
  2. Select the tool you want to configure (in this case: "TASKING Linker")
  3. Add the flag "--non-romable" in the Expert Settings; Command line pattern
  4. Apply and build.
In addition, you may need to change the linker script
  1.
enrico_b
  4. Apply and build.
  1.
