AURIX™ Forum Discussions
User22661
10 replies posted 10 sign-ins 5 replies posted
What are the differences in usage and functionality between the two types of Memory Protection?
Infineon-AURIX_TC3xx_Architecture_vol1-UserManual-v01_00-EN.pdf
Infineon-AURIX_TC3xx_Part1-UserManual-v01_00-EN.pdf
cwunder
cwunder
Could you be more specific in which two as there are many more protection schemes?
Traps are per CPU that the CPU can take upon an exception.  The SPR_SPROT_RGNLAi can be used to control access from other masters that want to access the PSPR/DSPR of a particular CPU.
thanks
I've seen what they do
cwunder
THANKS
