robs1
Level 4
Level 4
100 sign-ins 50 replies posted First solution authored
I want to have for ATOM module a clock0 equal to 200 MHz but I don't know how to set it because I obtain always a clock of 100 MHz. Can you help me with errors?
I use this lines of codes:
gtm_ptr->CMU.GCLK_NUM.B.GCLK_NUM = 0x1;
gtm_ptr->CMU.GCLK_NUM.B.GCLK_NUM = 0x1; /* write twice to be sure, taken from specs */
gtm_ptr->CMU.GCLK_DEN.B.GCLK_DEN = 200000000/CLK_FREQ;
gtm_ptr->CMU.CLK[0].CTRL.B.CLK_CNT = 0;
gtm_ptr->CMU.CLK_EN.B.EN_CLK0 = 0x2;
robs1
Level 4
Level 4
gtm_ptr->CLS_CLK_CFG.B.CLS0_CLK_DIV=1;
gtm_ptr->CMU.GCLK_NUM.B.GCLK_NUM = 0x1; // write twice to be sure, taken from specs
gtm_ptr->CMU.GCLK_DEN.B.GCLK_DEN = 1;
Using these lines of codes the code doesn't run
DownyK
100 replies posted 10 solutions authored 250 sign-ins
Hello
which cluster did you use?
and Did you check FsourceGTM frequency to set 200MHz?
robs1
Level 4
Level 4
I am using channels of atom 0 and How Can I check FsourceGTM frequency?? I have to write which line of code? Thank you
DownyK
I don't know which code did you use, so it's hard to explain it with a code.
If you look at the document, you can use 200 MHz by setting the GTMDIV to 1 within the CCUCON0 register.
DownyK
First, GTM frequency is derived from SPB frequency, and SPB is derived from syspll.
And Syspll is made as below.
If you use a 20MHz external oscillator, you can get a syspll of 300MHz by setting the P divider to 29, the K2 divider to 1, and the P divider to 0.
Then go to the Register below and set SPBDIV = 3 and GTMDIV = 1, and you will get a GTM frequency of 200MHz.
Then the CLS0_CLK in the figure below will be 200 MHz. If you use it without Global Clock Divider, you can use 200MHz as it is.
robs1
Level 4
Level 4
Hi, thank you! So it is enough to set the GTMDIV to 1 within the CCUCON0 register?
About the following passages I am not sure about "If you use a 20MHz external oscillator"... I am using only the board I have not an external oscillator. Did I understand correctly? Or it is an oscillator that I can set inside the board?
robs1
Level 4
Level 4
DownyK
in your board, Did you have any external oscillators?
so then Did you use only the internal clock?
as far as I know, Aurix has 2 Clock sources.
the first option is an external oscillator and the second is a backup clock.
robs1
Level 4
Level 4
I use internal clock (system clock 300 MHz)
and for ATOM so I use GTM clock 200 MHz but it set by default 100 MHz for gtm
