AURIX™ Forum Discussions
Tonny
First solution authored 25 sign-ins 10 replies posted
Hi Infineon Expert:
In Tc3XX target specification EVADC Module chapter described: Primary group conversion time is 0.5us, I don't clear understand that the 0.5us is for all channels of a group or a just a channel consumption time. please give some advice. thank you!
Tonny
dw
100 likes received 750 replies posted 10 likes given
The conversion time please refer to user manual for above example. 2.6MS/s is showed in the table. And the conversion is paralleled.
Tonny
Hi dw:
Thanks for your reply. I know that different groups can converter paralleled. But for in a group, different input channel converter converts one by one. cause there is only one converter module in a group. The converter speeds you mentioned above maybe for a channel.
dw
I also think so Tonny.
Tonny
Thank you, dw!
