Hi Infineon Expert:
In Tc3XX target specification EVADC Module chapter described: Primary group conversion time is 0.5us, I don't clear understand that the 0.5us is for all channels of a group or a just a channel consumption time. please give some advice. thank you!
Thank you, dw!
The conversion time please refer to user manual for above example. 2.6MS/s is showed in the table. And the conversion is paralleled.
Hi dw:
Thanks for your reply. I know that different groups can converter paralleled. But for in a group, different input channel converter converts one by one. cause there is only one converter module in a group. The converter speeds you mentioned above maybe for a channel.
I also think so Tonny.
Thank you, dw!
