Hello Community,
I m working on a Vector FBL on Tc3E7 and i m trying to communicate with an SBC using QSPI4.
I configured the Baudrate to 500000 and the fQSPI to 160Mhz.
I m using Mcal SPI driver.
using the logic analyzer(screenshot below), I saw that the clock is sent out with the correct frequency, the MOSI data is correct, the chipselect is also triggered correctly and there is data returned from SBC in the MISO line.
However, the SPI does not read the data in MISO line and returns FFFFF intead.
Do you have any hints what could be the issue here ?
Could you please try QSPI2 and QSPI3?
Above code is example for your reference.
dw
Please use duplex mode to try.
The QSPI operates in one of three modes regarding the direction of the communication and depending whether the transmission and the reception appear simultaneously or not: duplex, half-duplex and simplex mode.
This gives six possible combinations for the operating mode of the QSPI: master duplex, half-duplex, and simplex; slave duplex, half-duplex, and simplex.
Hello DW,
Thank you for your inputs.
Sadly, i m integrating on a remote customer HW, and only QSPI4 is used, so I cannot experiment with other QSPIs.
I m using MCal spi, and according to the user manual :
"The SPI driver operates in the master and full duplex communication modes only. The driver supports
synchronous and asynchronous communication supporting Level-0, Level-1 and Level-2 type configurations."
So it seems i configured master full duplex and Level0.
What confuses me is the bus trace looks ok, but it seems i can't read the MISO, is there any special register that i have to check, or hint to where i can look for , as it doesn t make sense for me why it cannot read the data that seem to be correct.
It's useful if you post all the registers' value of QSPI.
Here is the QSPI4 registers after i sent the first command :
QSPI2_ACCEN0 0xffffffff
QSPI2_ACCEN1 0x0
QSPI2_BACON 0x17224025
QSPI2_BACONENTRY 0x0
QSPI2_CAPCON 0x0
QSPI2_CLC 0x8
QSPI2_DATAENTRY0 0x0
QSPI2_DATAENTRY1 0x0
QSPI2_DATAENTRY2 0x0
QSPI2_DATAENTRY3 0x0
QSPI2_DATAENTRY4 0x0
QSPI2_DATAENTRY5 0x0
QSPI2_DATAENTRY6 0x0
QSPI2_DATAENTRY7 0x0
QSPI2_ECON0 0x1450
QSPI2_ECON1 0x47c4
QSPI2_ECON2 0x1450
QSPI2_ECON3 0x1450
QSPI2_ECON4 0x1450
QSPI2_ECON5 0x1450
QSPI2_ECON6 0x1450
QSPI2_ECON7 0x1450
QSPI2_FLAGSCLEAR 0x0
QSPI2_GLOBALCON 0x21003c00
QSPI2_GLOBALCON1 0x7ff
QSPI2_ID 0xc0c005
QSPI2_KRST0 0x0
QSPI2_KRST1 0x0
QSPI2_KRSTCLR 0x0
QSPI2_MC 0x0
QSPI2_MCCON 0x0
QSPI2_MIXENTRY 0x0
QSPI2_OCS 0x0
QSPI2_PISEL 0x1
QSPI2_RXEXITD 0xffffffff
QSPI2_SSOC 0x20000
QSPI2_STATUS 0x4401e00
QSPI2_STATUS1 0x0
QSPI2_XXLCON 0x0
Above is my QSPI2 register value for your reference.
Did you notice any unusual settings in my config, I think, as the baudrate requirement are different for you and me, it's not expected to have the same config.
Also, as I'm using Tricore MCAL spi driver, I expect it to write the correct registers, and explained, the transmit works fine, but just the reception in the miso.
I thought it might be a pin config issue, voltage level or something like that, I played with Cmos and TTL levels, no change.
What I noticed also, that the RXFIFO level is set to one when we transmit something and before we read the REXIT register, so we received something, but it s read FFFFF when the logic analyzer shows otherwise, I don t know yet.
Lautherbach doesn t show me the content of the ENtry and REXIT registers, so i don t know if there is anything inside, is this normal ?
This issue is reported internally for QSPI4. If possible, please use QSPI0/1/2/3 to try.
Hi DW,
unfortunately, the SBC is soldered to Port 33 using pins 9, 11, 12 and 13 so we can t change QSPI4 without redesigning the board.
But does your statement mean that it is a known issue for QSPI4 in TC3E7 and there is an eratta for it? or did you report my issue internally, for me to know what to report to project management?
Thank you very much!
Hi Dw,
I don t know what I did, but know the SPI communication is working!
Thank you very much for your kind support!
Hi Noblesse, It's better to compare the project source file previous one and currently working one. Then will know if any settings impacts.
dw
