Feb 27, 2020
04:33 AM
Feb 27, 2020
04:33 AM
Hi Aurix experts!
I'm trying to run an elf file on a TC399XP device mounted on a TC389 TH V2.0 EVB.
I'm flashing the elf using Infineon memtool - this part goes well (see attached flashing log)
The elf I'm trying to run is built from automatically crated example code in Hightech IDE (TimerDemo), however the LEDs that are supposed to flash are not flashing...
I tried connecting MCDS trace viewer for debugging and it seems that the device is locked (see screen cap).
Any idea what is this lock?
I tried unlocking the device's PFLASH and DFLASH using Infineon memtool and got the same result.
If I try to attach the tracer I see that the CPU is halted which might explain why the code is not running.
Any advice how to unlock the device and have the code running?
Yagi
Yagi
02:06 PM
Feb 27, 2020
02:06 PM
Hi Yagi. MCDS trace viewer requires an Emulation Device with trace memory (e.g., TC399XE).
Feb 27, 2020
08:56 PM
Feb 27, 2020
08:56 PM
Thant's strange as MCDS works for my when I use a TC389QP device.
Mar 02, 2020
03:50 AM
Mar 02, 2020
03:50 AM
TC38X has miniMCDS...
