Hi, I used the TC397 Core0 and Core1 to run our application, Core0 for main application, Core1 for peripheral control.
My problem is, when I tried to call the reset function "IfxScuRcu_performReset(IfxScuRcu_ResetType_application,0x0000)" at Core0, it will stuck at Core0 initial step.
Any comment or suggestion will be appreciated.
Thanks for your reply, this issue had been fixed with the "IfxScuRcu_performReset(IfxScuRcu_ResetType_system,0x0000)" , it seems like the reset type problem.
where exactly does it stop? Did you try to do the application reset without debugger connected as well?
TBencher
