AURIX™ Forum Discussions
9ball
First solution authored First reply posted First question asked
Hi guys,
I'm using TC397 to control an external DAC via SPI. I don't need the MISO signal, because the DAC is not sending anything.
/* Select the port pins for communication */
    const IfxQspi_SpiMaster_Pins qspi0MasterPins = {
        &IfxQspi0_SCLK_P22_8_OUT, IfxPort_OutputMode_pushPull, // SCLK Pin
        &IfxQspi0_MTSR_P22_10_OUT, IfxPort_OutputMode_pushPull,// MOSI Pin
        NULL_PTR, IfxPort_OutputMode_none,   //MISO pin not defined. Is this correct?
        IfxPort_PadDriver_cmosAutomotiveSpeed3  // Pad driver mode
    spiMasterConfig.pins = &qspi0MasterPins;    // Assign the Master's port pins
 Is this "NULL_PTR, IfxPort_OutputMode_none"  the correct way to do this?
Thank you!
9ball
Thank you -  I was trying to find out how to define the MISO pin in the  IfxQspi_SpiMaster_Pins struct if the pin is not needed. I guess NULL_PTR  is the answer, I saw it used in  other peripheral examples. (like UART).
Nambi
250 replies posted First like given 25 likes received
9ball
Thanks for the fast reply Nambi, unfortunately the link in the thread post  you mention doesn't work , even though I have myicp access.
https://myicp.infineon.com/sites/microcontrollers-aurix_customer_doc/Lists/defaultdoclib/AURIX%20TC3...
Nambi
Looks like the hyperlink was different from the text. I have updated the link in your response.
Best Regards.
9ball
