Hi all,
I'm trying to develop software on board KIT_A2G_TC397_3V3_TFT with AURIX IDE. Previuosly I used the TC277_TFT without problems. On this board I'm having a issue.: when I try to debug or flash a project a internal hardware error appears. I think this is related to the start up of the board. Indeed there is a blue led blinking and the display is always blue. I think there should not be the blue led and the display should be turned off, as on the TC_277_TFT. I've tried on two TC_397 board and the behaviuor is the same. As any of you encountered the same issue?
Thank you for the support.
I would recommend you to download the latest version of ADS(Aurix Development Studio)
https://www.infineon.com/cms/en/product/promopages/aurix-development-studio/
You can import the Blinky_LED project from ADS, program it and test it for a sanity check. Later you can try adapting your application-specific code.
Best Regards.
Best Regards.
