Ralphance
25 sign-ins 5 likes given First like received
Dears:
    I can modify other TC397XP chips to unlock according to the following method, but there is a development board, the program flashing and running are OK, but the following methods cannot be used to unlock and modify the startup address, please ask this developer How to solve the problem of the board.
Please read chapter 6.5.4.3.1 for further details. I have attached a screenshot to let you know what the confirmation words means. In above scenerio you need to Unlock the device again by clicking Unlock button.
Try following steps:
  1. Run Prepareonly script
  2. click edit button
  3. click unlock
  4. configure the parameters again
  5. click update
  6. click write
BR
Thank!!!
Di_W
https://community.infineon.com/t5/AURIX/how-to-unlock/td-p/357226
Hi ralphance,
I have attached the related thread. Could you explain a bit more on details? Do you mean only one board cannot unlock, right?
dw
Ralphance
Yes, currently only one board cannot be unlocked, the others can be unlocked.
Thanks!!!
Di_W
Has it been programmed with an unknown password?
Ralphance
What exactly is the unknown password you are talking about? I am not sure if this operation is used. If there is the above operation, how should I solve this problem?
Thanks!!!
Di_W
If you check Chapter 6.8.2.1 of user manual of TC3xx, you can see List of Defined UCBs from UCB00 to UCB47
For UCB_BMHDx(x=0-3), there is PW0-PW7, 8 WORDs = 256bit password protection
For UCB_PFLASH, there is PW0-PW7, 8 WORDs = 256bit password protection
For UCB_DFLASH, there is PW0-PW7, 8 WORDs = 256bit password protection
For UCB_DBG, there is PW0-PW7, 8 WORDs = 256bit password protection
For UCB_ECPRIO, there is PW0-PW7, 8 WORDs = 256bit password protection
For UCB_SWAP, there is PW0-PW7, 8 WORDs = 256bit password protection
dw
