Dear SIR,
Where to find the pin mux setting of TC397? Is there any documentation or tool?
Aurix
- tc397
There is no dedicated tool.
You can refer to the example https://www.infineon.com/aurix-expert-training/Infineon-AURIX_GTM_TIM_Capture_1_KIT_TC397_TFT-TR-v01...
You can refer to the section "26.3.2 Port to GTM TIM Connections" at https://www.infineon.com/dgdl/Infineon-AURIX_TC39x-UserManual-v01_00-EN.pdf?fileId=5546d462712ef9b70... for Port to TIM mapping.
Best Regards.
Are you referring to the different functionalities supported by each pin?
If so, you can refer to the section "2 Pin Definition and Functions" in the datasheet https://www.infineon.com/dgdl/Infineon-TC39x-DataSheet-v01_02-EN.pdf?fileId=5546d462712ef9b7017140bc...
Best Regards.
Hi Nambi,
If wants to config P00.1 to GTM_TIM5_IN5_11, all I know now is to set the IOCR0.PC0 to b'0xx10.
Besides there are many MUX needs to set, is there any documentation to describe it?
Or there is a tool for ARUIX like below?
https://www.infineon.com/cms/en/design-support/tools/utilities/fmx-pin-and-code-wizard/
Best Regards.
