TC397 Micro Kernel ISR configuration
Preth123
5 replies posted 5 sign-ins First solution authored
I am currently working with the safety OS in TC397. The microOS module is enabled and also the MicroKernel in OS configuration is enabled. Already for the Can Demo along with the package 3 ISR's are configured but with the same pririty. when a new ISR is added to OS configuration, liking error is shown as in attachement
What could be the reason and how can a new ISR be added to Micro kernel enabled configuration.
Nambi
500 replies posted 50 likes received 5 likes given
Hi Team,
Could you kindly check this with the Os Vendor since the issue is more associated with Os and Os configuration?
Best Regards.
Nambi
Hi Team,
Best Regards.
