The FlexRay demo program initialization using TC397 cannot be completed and loops indefinitely in a do while statement. Since the controller entered integration-listen state, may I ask why this state is and what does this state represent? How can I make hardware or software adjustments? Thanks
Hi Joe, could you please tell which package is the source code in? Thanks.
Hi Joe, please first to refer below 41.3.6 chapter in user manual.
Dear @Di_W :
I also encountered the same problem, it kept stopping in the do...while loop as below,
The value of pocState always keep at IfxEray_PocState_integrationListen.
According to your suggestion, I can’t figure out how to solve it after referring to Chapter 41.3.6. Do you provide Flexray’s application note? Or other files?
Thanks!
Wilson
HI,
I have encountered the same problem as you. Have you solved your problem?
Looking forward to your reply
Hi @Di_W
1. I used Tri-Board TC397 V2 EVB, and I didn’t find any example code for FlexRay. So I used the code here (TC397 FlexRay Demo.zip), but it didn’t work.
2. I’m not sure what you mean by user manual refer below 41.3.6.
Can you provide Flexray example code that will work?
Wilson
