Hello Team,
We are using MC-ISAR_AS422_TC3xx_BASIC_1.40.0. When we are doing ADC configuration with Davinci and EB tresos,
Configuration is successful. Adc_Init is getting called from EcuM_Stub_Callout.c and configuration values are also reflecting in Adc>PBCfg.c file. But when we are trying to see register set for EVADC in trace32, we are not able to see configuration.
Do you know what will be the reseaon.
For most peripherals, the registers aren't visible until the CLC register is set (e.g., EVADC_CLC.U=0). Are the registers still not visible after Adc_Init completes?
