TC387 technical reference or detailed datasheet
dk_y
Hello.
I am trying to make a three-phase motor driver inverter using aurix tc387.
In the meantime, I have been using TI's DSP a lot, and I am trying Infineon's chip for the first time.
I am configuring the basic code such as the interrupt, ADC, PWM, etc. of the chip.
However, there is no detailed description of registers in the datasheet of TC387, and in the case of TC387, example codes are also not enough.
Where can I get a datasheet detailing the registers of the TC387?
Thank you very much.
Aiswarya_A
25 likes received 250 sign-ins 50 solutions authored
You could refer to the TC38x_appx_um_v2.0.
Kind Regards,
Aiswarya.
Aiswarya_A
Kind Regards,
Aiswarya.
