Aug 06, 2021
03:23 AM
Aug 06, 2021
03:23 AM
Hello intelligence cluster,
our TC387 persists on low-level at /ESR0 and thereby stays in RESET state. The controller is in fresh original condition, no SW, no changes to UCB.
Any idea what can cause this?
No shortcircuit from /ESR0 to GND. In deenergized condition we measure 4k to GND, the same as on /ESR1.
GyroGearloose
GyroGearloose
01:42 AM
Aug 09, 2021
01:42 AM
MoD wrote:
If you have really connected 3,3V to VDD as in picture then you have an overvoltage condition on VDD and I expect that the device is killed. You need 1,25V on VDD.
Sorry, my fault. VDD is already 1V25, but thank you for your hint!
PROBLEM SOLVED THREAD CAN BE CLOSED
The decesive factor was the external circuit on P20.2 General-purpose input (testmode enable pin).
External pull-up to 5V solved it.
Thanks alot for your ideas!
Bye GG
Aug 06, 2021
04:08 AM
Aug 06, 2021
04:08 AM
ESR0 means that the Tricore has remained in the Infineon Boot Code, the SSW. This can commonly be caused by misconfigured UCBs, but you mentioned you have not changed them. Also, in the case that there are two SMU related resets consecutively, then ESR0 will remain low. The SSW will hold the IC in Infineon boot if this is recognized. Look at "Double SMU Resets" in the manual. But this signature as you show it does not line up with what I would expect for a double SMU reset. And by default, only the Watchdogs, and Recovery timers tied to them, can generate an SMU reset.
Aug 08, 2021
12:48 PM
Aug 08, 2021
12:48 PM
You need to program the UCB_BMHD0_ORIG and COPY with a valid configuration.
Aug 09, 2021
01:10 AM
Aug 09, 2021
01:10 AM
Aug 09, 2021
01:42 AM
Aug 09, 2021
01:42 AM
Bye GG
Oct 05, 2021
02:37 AM
Oct 05, 2021
02:37 AM
Hi All
I have the same issue (ESR0 alwasy at low level). It happened after I tried to download the SW with the build-in functionality of the Tasking compiler. The download failed immediately and later, trying with the Lauterbach, I'm no more able to connect.
There is something I can check? I'm working on the triboard TC377
Oct 05, 2021
08:22 AM
Oct 05, 2021
08:22 AM
UCBs seems fine. I manage to connect with the Memtool via serial (changhing the HWCFG pins). I'm right? What alse could lock ESR0 to a low value?
Oct 06, 2021
09:50 AM
Oct 06, 2021
09:50 AM
So you are saying that MemTool is connecting while Lauterbach or iSystem is not connecting.
Is that correct?
Oct 06, 2021
09:55 PM
Oct 06, 2021
09:55 PM
Yes, But Memtool via serial (BSL/ASC). Memtool via DAS also do not work.
Oct 07, 2021
01:19 AM
Oct 07, 2021
01:19 AM
Measure the ESR0 signal with an oscilloscope. The signal should be go to high for a short time, if not and the signal stays always at low then device is broken (e.g. erase BMHDx..ORIG and ..COPY) and can't recovered. In this case you can only exchange the device.
Oct 07, 2021
01:39 AM
Oct 07, 2021
01:39 AM
UCB_BMHD0 start address is not correct, u should set it to internal program flash address -> 0x80000000
Oct 07, 2021
02:04 AM
Oct 07, 2021
02:04 AM
Thanks all for the answer
@MoD: ERS0 is always low, no transition is present at power up. But as above I can connect with the Memtool and the UCB seems correct (at least what we could see here) so I don't htink is broken or UCB corrupted.
@Vincent. Why is not correct? In my code this is the starting address. Also other board have the same starting address and are working properly.
I've another idea.. I've seen is possible to download a SW with the memtool but the address allowed are only Axxxxxxx. My code runs on 8xxxxx. I can move my code to Axxxx and download the code via the memtool but then the starting address into the UCB will be wrong. Is is feaseable to change it via the memtool (I've never done it).
Only change the value and press write or some other steps are necessary (checksum, UCB copy update, password to enable writing)
Oct 07, 2021
03:37 AM
Oct 07, 2021
03:37 AM
this screenshot showed start address -> invalid
Oct 07, 2021
04:16 AM
Oct 07, 2021
04:16 AM
The actual configuration is on the left (at least I suppose). On the right is the value you can set. I think is presented as "invalid" because memtool manage only on the address 0xA000000
Oct 07, 2021
09:01 PM
Oct 07, 2021
09:01 PM
are u able to set start address -> 0xA0000000 & click Write configuration?
after that, reset ur device & check ESR0 status.
how about content of BMHD1/2/3?
u mentioned "It happened after I tried to download the SW with the build-in functionality of the Tasking compiler. The download failed immediately and later....." so might be did not finished erasing/programming flash content -> corrupted UCBs?
so ESR0 always Low.... then comment from MoD is correct -> "Measure the ESR0 signal with an oscilloscope. The signal should be go to high for a short time, if not and the signal stays always at low then device is broken (e.g. erase BMHDx..ORIG and ..COPY) and can't recovered. In this case you can only exchange the device."
can focus on what is the difference that u have done (ie, procedures) between a good unit & bad unit.
Oct 07, 2021
10:32 PM
Oct 07, 2021
10:32 PM
Hi Vincent
BMH1/2/3 are empty and not valid.
About the "sequence" I've not done anything different than the other time (or at least I think :-\).
I've just now downloaded a SW with the addresses moved to 0xA0000020 but still not work, probably because it is in the wrong location the starting address pointer... Then I've tried to write the address via the memtool but it ask to re-write a password and actually I don't find any reference on what is a proper value to write here
Oct 08, 2021
03:43 AM
Oct 08, 2021
03:43 AM
Sorry, I am a little confused now. If the ESR0 signal is always low then you can't download any software to the device. What is not working in your case?
Oct 08, 2021
04:35 AM
Oct 08, 2021
04:35 AM
I can do it with the Memtool connected via serial. When I select the proper HWCFG pins I can connect with the Memtool and the ESR0 is no more kept low (till I'm in this mode).
BTW I've changed the starting address manually, pressed WRITE -> Ok on the default password request and in the latest confirmation windows with the disclaimer "you could lock the possibility to flash again the target" I've selected NO to abort the request . Or at least it should have aborted the writing request but probably in any case something has been changed... now I can connect with the lauterbach and the uC is working again:-\.
Oct 11, 2021
12:08 PM
Oct 11, 2021
12:08 PM
Can you please elaborate HWCFG pin configuration when you connect as BSL Mode?
Also, how are your physical connection mechanism from Host to Target hardware?
Oct 12, 2021
10:06 PM
Oct 12, 2021
10:06 PM
Yes sure. I'm actually working on a Triboard demoboard so I've a DIP switch where I can easly change the HWCFG pins configuration.
The connection is done with the onboard circuit present on the board. I think is the same HW of the miniwiggler.
Oct 13, 2021
04:46 AM
Oct 13, 2021
04:46 AM
So, to which pins on TriBoard you are connecting the Host PC interface using miniwiggler external USB Adapter so that MemTool can perform initial BSL related RAM download?
Oct 13, 2021
11:07 PM
Oct 13, 2021
11:07 PM
PC is connected to the Triboard USB. Then there is a build in debug/program interface on the Triboard (I think is the same HW more or less of the miniwiggler) that is connected to the uC. You can check the triboard schematics for the wiring. Then I connect via the Memtool in ASC/BSL mode (DAP mode do not work in my case till the uC was in "locked" condition).
