Hi everyone:
I had configured in application project Ifx_Cfg_SswBmhd.c file the start address is oxA00008000:
bmhd0~bmhd3's configuration in application project is same,
const Ifx_Ssw_Bmhd bmhd_0_orig = {
0x00FE,
0xB359,
0xA0008000, /**< \brief 0x004: .stad: User Code start address*/
0x31795570,
0xCE86AA8F,
and in the bootloader project the start address is 0xa000000, bmhd0~bmhd3's configuration in bootloader project is same,
0x00FE,
0xB359,
0xA0000000, /**< \brief 0x004: .stad: User Code start address*/
0x31795570,
0xCE86AA8F,
I want to know that whether the configuration is reasonable or not. thank you.
You can use Memtool 2021 to modify UCB_BMHD0 and save .hex for reference. As you changed something the checksum should be changed also. Below is for your reference.
dw
dw
Hi dw:
It's a very important key point you had offered, thanks a lot! and I want to know if I configured in my c program bmhd configuration, Boot project starts from 0xa0000000 and application starts from 0xa0008000. I wonder to know whether the configuration is finished or some other configuration should i had missed!
I think the .map file should be checked. for example:
