TC387 EDSADC Resolver Application
Tonny
25 replies posted 10 questions asked 50 sign-ins
Drar Infineon Expert,
We're using the tc387 EDSADC for resolver application,and we learned some important information from AP32554.
My question is how to design the timing of the software to realize the updating of the sampling results(by service request or
polling, and how to use the sampling results), and the implementation of the SDCAP delay compensation function.
Is it possible to provide some demo of the software design?
Thank you!
Kunqiao_L
First comment on blog First like given 25 likes received
Hi Tonny,
Unfortunately we don't have particular demo for that, but we do have some code example for how to configure EDSADC and run it:
EDSADC_1_KIT_TC397_TFT
There is also another Application note to check:
EDSADC_Configuration_for_Resolver_Application_v1.0.4.pdf
BTW, there are some community's questions that about sampling the result and calculate SDCAP:
DSADC-trigger-controlled-mode-for-resolver
Aurix-TC365-EDSADC-Return-Signal-Synchronization
Hope could help you little bit, thanks.
Kunqiao_L
Hi Tonny,
Hi likunqiao:
Thank you very much for your careful reply! I'm concerned more about as I had mentioned above, After initialization, how does the program get the sampling results, whether it uses interrupt routing or polling and how these sampling results are subsequently processed. Looking forward to your reply, thanks!
Kunqiao_L
Hi Tonny,
Please refer to the code example that I provided:
EDSADC_1_KIT_TC397_TFT/EDSADC.c
It contains how to get the result (IfxEdsadc_Edsadc_getMainResult) and it uses polling method to get result.
If you want to use interrupt, just simply register these channel to src with priority.
refer this function: IfxEdsadc_Edsadc_getMainSrc
Hi likunqiao:
Thanks you answer. Further more, I would like to understand how these sampling results  are handled in the subsequent software in Resolver application. Please provide some details, much appreciated!
Kunqiao_L
Hi Tonny,
There is no demo code for resolver application, the code example only provided till getting the EDSADC result, for further data process like rectification, sin/cos to tan to get the motor rotary angle, user has to develop by himself. Please refer to the application note to see the how it process in principle.
Kunqiao_L
Hi IFX_likunqiao,
We have buy this kit, it's not include them. thank you!
Kunqiao_L
Yes, you are right. I checked the code, it might not include resolver solution:
Again, you might to implement it by yourself
Okay, thanks. I'll study the user manual.
