mimeshy1
10 sign-ins 5 questions asked First like given
对于手册中Buffer Type中FAST ,SOLW,PU1,VEXT,ES这些类型如何理解?
我使用TC387的GPIO口对100HZ-500HZ的PWM信号进行采样需要注意什么?
Di_W
For detailed descriptions of the "Buffer Type," you can consult the document tc39x_ds_v10.pdf or similar documents. The following buffer types are listed:
RFAST
FAST
SLOW
LVDS_TX
LVDS_RX
S
D
Porst
XTAL1
XTAL2
PU
PU1
PU2
PD
PD1
PD2
OD
ES
ES1
ES2
ES3
ES4
ES5
ES6
对于PWM采样,除了GPIO外,还有ADC/CCP比较捕获/定时器,可以使用。例子代码可以参考github https://github.com/Infineon/AURIX_code_examples/tree/master/code_examples
如果确定使用GPIO,那么可以设置一个定时器中断,比如每毫秒进入一次中断,然后读取GPIO的值。这个精度和效率是比较低的,所以可以考虑使用其他模块,比如CCU6,例子代码如下:
https://github.com/Infineon/AURIX_code_examples/tree/master/code_examples/CCU6_PWM_Capture_1_KIT_TC3...
Di_W
RFAST
FAST
SLOW
LVDS_TX
LVDS_RX
S
D
Porst
XTAL1
XTAL2
PU
PU1
PU2
PD
PD1
PD2
OD
ES
ES1
ES2
ES3
ES4
ES5
ES6
