Dears, Hello,
My first post.
I have just started working on TC387 5V TRB A2G kit.
It seems that there are several code examples for iLLD for this target but I am not able to find them.
I found "chm" for iLLD but it does not work also (I can just open it but nothing can be displayed afterward).
I'm looking for some software developer guide or something which can help me to understand the iLLD and other drivers for example, for 5V_TRB evalboard please.
I looked a lot around but I couldn't find any. Any help would be greatly appreciated!
below screenshot of the chm for iLLD which is not working.
Examples found only for the TFT version (nothing for the TRB):
Thanks!
Akd
I did have the same problem quite a long time ago. As I remember it was just a small problem. But I did not make any notes about it. Can you try to start your iLLD documentation just with administrator rights?
TBencher
Hi Akd,
https://github.com/Infineon/AURIX_code_examples/tree/master/code_examples
Please refer to the example code as above link. And if you use ADS to import a project from the menu FILE, they should be the same.
For training materials, please refer to Quick training and Expert training pdf in below link, specially this doc:
For datasheet and usermanual, you should register myICP and download from there.
https://www.infineon.com/cms/en/product/promopages/MyICP-platform-for-Microcontroller/
In myICP, you can download iLLD with different version as below showed:
dw
