Hi all:
I have a problem now, I want to flash the program when we flash the hardware with DAP miniWiggler , it cannot recognize the chip of TC377, and I can rule out the problem of my hardware.
I also used the TRACE32 ICD TriCore USB to try to flash , prompting the CPU did not halt after reset. Error Debug port is displayed after CPU reset
Hi BigHao,
Please refer to Triboard User Manual of TC377, which includes a sch and hardware HWCFG pins explainations. Which could help you understand the difference of your board and Triboard.
dw
Hi BigHao,
Have you used the Triboard or TFT board or customized board? For Triboard, you could use default settings and connect DAP miniWiggler to download the .hex file.
dw
Sorry, I don't have Triboard or TFT board。
Hi BigHao,
dw
