I am currently trying to provoke an application reset on core0 of TC367D using the IfxScuRcu_performReset(IfxScuRcu_ResetType_application, (UINT16)0x0000); function (I also tried with the example code from the Gitlab, but the result is the same).
Whenever I do that, the microcontroller gets stuck afterwards (during the reset I guess). Is there any way to attach to the running target to see what is happening ?
Can you please tell me if there is anything else to be done (the watchdogs have been previously disabled) ? Is there any specific state in which the other core should be when reseting? Any lead can be helpful !
Thank you !
Hi Ana,
1. Is the debugger connected during your test? Can you check without the debugger?
2. Are you triggering the reset based on a condition?
eg:
uint trigger_reset=0;
if( trigger_reset = 1)
{ triggerSwReset(); }
If the reset is triggered unconditionally, it is possible that the device is getting reset repeatedly and stuck. You can toggle a GPIO/LED at the beginning of your main() before calling reset. During your test without the debugger, you can check if there was a reset or continuous resets based on the GPIO/LED toggle.
Nambi.
Can you try the triggerSwReset() function from the example SCU_Reset_Detection_1 for KIT_AURIX_TC397_TFT in ADS(Aurix Development Studio)
Best Regards.
Yes, I tried it and the result is the same. Do you have any idea why ?
Ana
Hi Nambi,
Any update on this topic ?
Hi Ana,
eg:
Nambi.
