OceanLake
10 replies posted 10 sign-ins 5 replies posted
Dear All. When I using the PLS UAD2 pro connect with Aurix TC364 ECU,
Error will be reported as follow picture:
How to solve this problem?
Looking forward to your reply.
Jeremy_Z
1000 replies posted 250 sign-ins 100 likes received
Hi @OceanLake  ,
In my opinion, it's too hard to confirm your assumption, as there's no other debug interfacing or porting for testing on the ECU unless unsoldering the chip to another platform for testing.
Moreover, I'd like to suggest you consider alternative ways to reflash the chip to get rid of the issue.
BR,
Jeremy
Jeremy_Z
Hi @OceanLake ,
1) How to solve this problem?
-- To be prudent, I'd like to know the context information of the issue, so can you give a brief introduction、
BR,
Jeremy
Thaks Jeremy,
Our product is used for motor control,The following is the background information of the problem,
1、Firstly, the workshop will write a test program for the ECU, which includes BMHD. After the operation is completed, the software will run normally.
2、Afterwards, the ECU will be used for motor related testing, and the software runs normally throughout the entire testing process.
3、After the test is completed, the shipping program will be refreshed. After connecting the flashing tool, erase the PFLASH area code, and the flashing tool will no longer be connected.
Approximately 1000 products will result in 6 failed pieces.
OceanLake
Jeremy_Z
Hi @OceanLake
Thanks for your information.
I'd like to know the phase in which t the above issue raises, further, the failure rate.
BR,
Jeremy
Hi @Jeremy
Thank you for your thoughtful reply.
The issue raise at step 3
"3、After the test is completed, the shipping program will be refreshed. After connecting the flashing tool, erase the PFLASH area code, and the flashing tool will no longer be connected.".
And the failure rate is zero point six percent(0.6%).
OceanLake
Jeremy_Z
Hi @OceanLake
Does this ECU also be designed by your company? Further, there are other debug interfaces or ports for testing on the ECU, such as, can you try this tool to connect the ECU?
Lastly, you can compare the voltage level of the JTAG pins between the good and failure ECU, if available, please tell me the testing result.
BR,
Jeremy
Hi @Jeremy
The ECU is designed by my company, unfortunately, No other debug interfaces or ports for testing on the ECU.
Following table is my test result, Voltage and resistance.
Status of ECU  TRST TMS TCK TDO TDI
Normal ECU 5V 0V 0V 0.5V 5V
Bad ECU 5V 0V 0V 0.5V 5V
Resistance.
Normal ECU 0Ω 6.7KΩ 21.6KΩ 0Ω 0Ω
Bad ECU 0Ω 6.7KΩ 21.8KΩ 0Ω 0Ω
BR,
OceanLake
Jeremy_Z
Hi @OceanLake
When measuring the voltage level (TRSI, TMS, TCK, TDO, TDI), please ensure the PLS UAD2 pro connects the debug port first, then, power on the ECU, capture the voltage level during PLS UAD2 pro try to establish the connection with the ECU, if the JTAG port has a fault, the voltage level usually behaves differently from the normal ECU.
BR,
Jeremy
Hi @Jeremey
The following is my test detail phenomenon.
RESET_EMU:
When powered on, it presents a high level, and when the debugger is connected, it generates two resets.
TRST:
When powered on, there will be a high level, and there will be some level changes when the debugger is connected.
TDO:
When powered on, there are high-level pulses, and when the debugger is connected, it will generate two high-level flat pulses.
TCK:
When the debugger is connected, there may be occasional clock generation.
TMS:
When the debugger is connected, there will be communication.
TDI:
Always at low level when powered on or connected to the debugger.
BR,
OceanLake
Jeremy_Z
Hi @OceanLake
Was the testing implemented on the bad ECU? Or both normal and bad ECU?
Are the testing results identical on normal and bad ECUs?
BR,
Jeremy
Hi @Jeremy
The testing implemented on the bad ECU.
BR,
OceanLake
Jeremy_Z
Hi @OceanLake
I'd highly recommend you do the same testing with the normal ECU and compare the results to the bad ECU.
BR,
Jeremy
Hi @Jeremy
Sorry for replying so late,The following information is for a normal ECU:
TMS:
afdcefe2-140c-4832-8b18-2c82866467ab.jpg.
TCK:
TDO:
TRST:
RESET_ECU:
TDI:
c9311939-c35c-4ada-b745-a8838b187eaf.jpg.
BR,
OceanLake
Jeremy_Z
Hi @OceanLake
According to the testing result, it seems like the JTAG port is not damaged.
I remembered that the issue was raised after step 3, and I'd like to know whether Bad ECU runs well after reflashing the demo code after step 3.
Further, can you tell me what flashing tool you used?
BR
Jeremy
Hi @Jeremy
After the step 3 is completed, the code in the ECU has been erased, and there is no program for the running current of the ECU. At this time, the debugger cannot be connected, and I cannot confirm whether the code in the ECU has been completely erased, not erased, or only partially erased.
My flashing tool is PLS UAD 2pro.
BR,
OceanLake
Jeremy_Z
Hi @OceanLake  ,
BR,
Jeremy
Translation_Bot
1. First check whether the power supply is stable, whether the current is sufficient, low voltage, and insufficient current will also lock the chip debugging port
2. When the chip burns the program, whether to set encryption protection
3. The BMI header is not set correctly, or there is a problem with the UCB modification.
4. Solution: Try connecting via miniwigger.
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/AURIX/TC364-JTAG-%E6%8E%A5%E5%8F%A3%E5%B7%B2%E9%94%81%E5%AE%9A/m-p/646916
