AURIX™ Forum Discussions
Dhiraj
First question asked Welcome!
I'm working with the Aurix TC364 infenion EVAL board. I am trying to make internal watchdog module up in Autosar Workspace. Where Watchdog Driver Configuration
is done with help of EB tresos. To check the watchdog functionality I configured ASW and added Deadline supervision StartCheckpoint and Endcheckpoint.
No delay is added between two checkpoint.
WatchdogManager and interface configuration is done with the help of manual.
After Flashing of Code immediately MCU goes in continous Reset even in debugging Mode (While Debugger is Connected) though no specific condition is added to reset MCU also check without debugger MCU going in continous reset.
What Could be the reason for reset.
Also on which pin I can identify internal watchdog resetting MCU?
DownyK
10 likes received 10 questions asked 50 replies posted
hello Dhiraj
I think you should check which reset occurs.
Can you check SMU debug status Register?
Prudhvi
25 likes received 50 solutions authored 250 sign-ins
As the question is part of MC-ISAR which is licensed, we request you to please contact your local Infineon, distributor or software reseller contact.
