peijun
First like given 10 sign-ins 5 replies posted
hi Sir
i am using taksing tool inside aurix develoment stuido.  i found that it alwasy can not locate files inside emem area.
you can see bellow map file,  there is nothe was maping to emem areas,  can you guide me how to check it.
i am working on TC35
Di_W
Dear Users,
Just notify that ADS doesn't support TC35x currently.  TASKING could be consulted for the .lsl related issue.
dw
peijun
i check that all locate rules inside map file result ( all of them are correct, which means my LSL script are ok),  but  why the locate result have no emem space. all the group which should link to Emem area are failed, it remind have no space.  is the tool support TC35? i am using  V1.5.4
Di_W
Dear Users,
I have checked MCMCAN_1_KIT_TC397_TFT on ADS1.5.4, I found EDMEM in .map file, and .lcl file includes the corresponding edmem definition.
Please check your .lcl file, it should be set correctedly.
2022_03_28_12_56_35_AURIX_v1.5.4_workspace_MCMCAN_1_KIT_TC397_TFT_Debug_MCMCAN_1_KIT_TC397_TFT.map.png2022_03_28_12_57_14_AURIX_v1.5.4_workspace_MCMCAN_1_KIT_TC397_TFT_Lcf_Tasking_Tricore_Tc.lsl_AUR.png
dw
peijun
hi DW
thansk your reply,    that is ture there is define in TC39 lsl,  but it was missing in TC35x.lsl.
i make a copy from TC39(modify size),  Emem was found now,  but still cannot locate  address. 0x99000000-0x99200000,  seems like cached space can not be found.
Quiet strange.
following are add to TC35X
memory emem0
mau = 8;
size = 1M;
type = reserved ram;
map cached (dest=bus:sri, dest_offset=0x99000000, size=1M, cached);
map not_cached (dest=bus:sri, dest_offset=0xb9000000, size=1M);
memory emem1
mau = 8;
size = 1M;
map cached (dest=bus:sri, dest_offset=0x99100000, size=1M, cached);
map not_cached (dest=bus:sri, dest_offset=0xb9100000, size=1M);
peijun
i modify TC35X.LSL inside tool like following.  and the error was not report anymore.
memory emem0
mau = 8;
size = 2M;
map cached (dest=bus:sri, dest_offset=0x99000000, size=2M);
memory emem1
mau = 8;
size = 2M;
map not_cached (dest=bus:sri, dest_offset=0xb9100000, size=2M);
not sure it will work after flash to device.
peijun
can you have a look on my new update
Di_W
       memory emem0
                mau = 8;
                size = 1M;
                map not_cached (dest=bus:sri, dest_offset=0xb9000000, reserved, size=1M);
        memory emem1
                mau = 8;
                size = 1M;
                map not_cached (dest=bus:sri, dest_offset=0xb9100000, reserved, size=1M);
        memory emem2
                mau = 8;
                size = 1M;
                map     cached (dest=bus:sri, dest_offset=0x99200000,           size=1M, cached);
                map not_cached (dest=bus:sri, dest_offset=0xb9200000, reserved, size=1M);
        memory emem3
                mau = 8;
                size = 1M;
                map     cached (dest=bus:sri, dest_offset=0x99300000,           size=1M, cached);
                map not_cached (dest=bus:sri, dest_offset=0xb9300000, reserved, size=1M);
Hi peijun,
I found above definition in below path. It's for your reference.
C:\Program Files\TASKING\TriCore v6.3r1\c51\include.lsl\tc37x.lsl
--above is in TC35X_ts_appx_V2.5.1.pdf
dw
Di_W
Dear Users,
dw
