123rtgr
10 questions asked 25 sign-ins 10 replies posted
l have some problem with spi. l used the same configuration of example of TC334 spi dma. And l can not send datas over 8 byte once. (The MOSI will be all high or all low)The transfer under 8 byte  is normal. So l guess lt's a configuration error. What should l configure to allow send datas over 8 byte.
Jeremy_Z
1000 replies posted 250 sign-ins 100 likes received
Hi @123rtgr
I was wondering if you could introduce your testing platform, such as demo code, board, etc.
Further, I'd like to suggest you refer to the demo at first.
BR,
Jeremy
Jeremy_Z
Hi @123rtgr
BR,
Jeremy
