PSAcars
Hello to all. I am a electrical engeener, I work mostly with automotive electronic modules  ( repair, clone, adaptation) In my work I find more and more the TC2xx based mcu. I found on official site memtool software and miniwiggler. Is that enough to READ and WRITE the TC2xx? I found around the web DAS Interface for this type of mcu, but no info about DAS Interface here in official site. Please help with advice what soft and hardware I will need to work with this MCU family?
Nambi
500 replies posted 50 likes received 5 likes given
You can check the "Design Support" section in the below link.
https://www.infineon.com/cms/en/product/microcontroller/32-bit-tricore-microcontroller/32-bit-tricor...
Best Regards.
PSAcars
Hello again, I did not found any thing related to DAS Interface and MEMTOOL, only different family of mcu short revues.
The question stays open.
boxOfPapers
5 sign-ins First solution authored First like received
One tool that could do both of those things is the iSYSTEM BlueBox. In addition to reading and writing the content, it also has trace capabilities that might come in handy for you in the future if you ever need to do any timing analysis, profiling or just catching that one elusive bug that's been blocking you for the last few days 🙂
