I use TC234 and TC275,wanted boot from ABM.
I uses only BMHD1.In linker file,this was configed:
RESET = 0x80020020;
.bmhd_1 (0x80020000) : FLAGS(arl)
BootModeIndex = .;
KEEP (*(.bmhd_1));
} > pfls0
In source file,I write the first user code and calculate the checksum:
const uint32 BootModeHeader_1[] = {
0x80020020u, /* STADBM first user code at 0x8002 0020h */
0xB3590064u, /* BMI = 0064h BMHDID = B359h disable HWCFG pins & ABM */
0x80020008u, /* ChkStart */
0x8002000Fu, /* ChkEnd */
0xEF947F9Fu, /* CRCrange */
0x106B8060u, /* !CRCrange */
0xE935730Fu, /* CRChead */
0x16CA8CF0u /* !CRChead */
When connected with debugger ,the program can run.If without debugger,it can't run.
What's wrong with it? Is anyone can help me? Thanks!
AURIX
Your BMI setting is not valid. The PINDIS is bit 3 which makes it binary 8. For alternate boot mode with HWCFG disable would be 068h.
Tank you very much!It works. I did miscalculate the BMI data.
