AURIX™ Forum Discussions
I have receive a Starter Kit TC265 (TriBoard TC2x5 v2.0) and I would like to get the User Manual to check the pinout, connections, etc.
In the infineon website I've found the User Manual / Hardware Manual for other TriBoards (like TC1798 and TC1784) but not for the TC265 nor TC2x5.
Could you please post the TC2x5 TriBoard User Manual link?
Thanks!
You will need to register with infineon and then log into https://iauth.infineon.com/my.policy. There u will be able
to search for all the documents u want. It is a shame that such expensive boards come with no documentation.
I have the same problem. I've registered and log into https://iauth.infineon.com/my.policy and I get redirected to the main page where there can't find the user manual for the Triboard TC2x5 v2.0.
Someone can help?
User13290
First solution authored
Someone can help?
I can't be sure but I suspect it might be for the same reason as I explained in this reply.
Henk-Piet Glas
Principal Technical Specialist
User17426
I have the SAME problem.
It is not what Henk-Piet Glas says.
It is NOT due to permissions on the Infineon site, I have already been through that process AND been approved.
I have used this permission to download multiple manual and data sheets that are NOT accessible to the general public.
If I search for this manual on "MyInfineon", it is simply NOT there.
If I search for "Triboard Manual", I see
"TriBoard Manual TC2X3",
"TriBoard Manual TC3X5",
"TriBoard Manual TC3X6 ADAS", and a bunch of others
....but NO "TriBoard Manual TC2x5" manual.
I'm checking with my FAE,
John Svinicki
NeMa_4793301
Level 6
Level 6
For those of you who have no problem logging into MyICP, here's a direct link to the TriBoard TC2x5 documentation:
https://myicp.infineon.com/sites/microcontrollers-aurix_customer_doc/Lists/MyICP%20Customer%20Docume...
