Dec 08, 2020
05:05 AM
Dec 08, 2020
05:05 AM
Hello Everyone,
I'm using a TC299 on a custom PCB. After a while, the MCU started to behave faulty. First, isystem debugger was unable to reset the device, hence it was unable to program the device. At this point I was able to flash my hex file with Infineon memtool, and miniwigler . Later, the memtool started to fail during erease operation. It doesn't prompt any error code. Otherwise I'm still able to connect to the target, and read specific address ranges. BMHD areas are filled correctly, so the device is not in bootstrap loader mode, and the debug interface isn't locked. What could cause such a situation? Are there any method to restore the mcu?
Dec 09, 2020
10:49 AM
Dec 09, 2020
10:49 AM
How many times have you flashed PFLASH and/or the UCBs? The datasheet specifies the maximum number of program/erase cycles.
Dec 09, 2020
11:09 PM
Dec 09, 2020
11:09 PM
Don't know exactly, but about 10-30 times
Dec 10, 2020
01:53 AM
Dec 10, 2020
01:53 AM
Which error code you get, which messages? What you are programming? Also some UCBs?
Dec 10, 2020
04:45 AM
Dec 10, 2020
04:45 AM
I have attached a screenshoot from the memtool. There is no error code prompted. I try to program the pflash from 0xA0000000 to 0xA000FFFF. UCB-s are not changed. BMHD areas are valid.
Dec 11, 2020
02:31 AM
Dec 11, 2020
02:31 AM
The is a menu point Log, Is there any error message?
Can you readout some register with a debugger? Which debugger?
Dec 11, 2020
02:47 AM
Dec 11, 2020
02:47 AM
I have attahed the log file output. Reading out is working. I'm using a DAP miniwigler3 as debugger
Dec 11, 2020
04:44 AM
Dec 11, 2020
04:44 AM
Did you change the RAM initialization via the PROCOND?
I have seen this when RAMIN=NoInit meaning the SSW will not initialize the RAM's.
afaik most debuggers will download a flash driver to PSPR RAM of CPU0. If this has not been written at least once there will be ECC errors in the RAM and the driver will fail.
Dec 11, 2020
05:41 AM
Dec 11, 2020
05:41 AM
I didn't changed it
