AURIX™ Forum Discussions
I need the complete data sheet and reference design document of these TC297TA, and TC299TX Tri core MCU family. as we have shortlisted this for my new safety critical device.
and what is the life-cycle longevity (in production, Not recommended for new design (NRND), Obsolete)of these MCU.
if in production then is this MCU available for next 7 to 10 years?
Mohsin Nabeel
cwunder
An Infineon sales representative in your area will be able to answer the longevity questions. This is a relatively new device from Infineon so it is at the beginning of its life-cycle. In regards to documentation, this is all available on the myinfineon via the myICP portal. Here are the instructions https://www.infineon.com/dgdl/Infineon-Customer_%20instruction_guide_for_myICP_version_2-ATI-v02_00-...
hi,
i have already registered and activated myicp account. i did not find any MCU document there (as show in image). or may be did not understand how to get from myicp share point portal
kindly share the procedure.
2866.attach
regards
Mohsin
User13290
First solution authored
Hi Mohsin,
mohsinn wrote:
hi,
Following your registration you have a restricted set of permissions of what you can see. To bump your permissions you must drop a line to AURIX@infineon.com and ask to be granted access to the documentation you're after. You must provide your myICP username so they know which profile to bump.
Henk-Piet Glas
Principal Technical Consultant
User12775
It is a very bizarre way to download datasheet and user manual.
I don't think they are such confident document that could not be listed at the open Infineon website.
Which manuals / datasheets are available for the Aurix family of MCUs ? I need 1) Aurix 2nd Generation TC3xx (firstly)
2) Infineon AURIX SAK-TC299TP-128F300N BC and if possible for the AURIX™ Family – TC29xT
3) Infineon AURIX SAK-TC297TX-128F300N BC
datasheets.
Can anyone send me please as an attachment here or to e-mail automovie_jobs@protonmail.com ?
Kind Regards.
