AURIX™ Forum Discussions
Good day ! I am completely new to tricore. I want to request TC27x Application Notes. Are these available in Infineon websites ?
I have a simple task as to implement a flash driver(which writes & erases a block).
Thank you
vk18434
User9888
You'll need to sign up to the MyInfineon program first. It will give you access to otherwise restricted documentation.
Henk-Piet Glas
Technical Product Specialist
@Henk-Piet Glas - Thank you very much. Is there any sample code I could see for Flash driver ?
User9888
Yes there is. There's one that explains how to use flash programming via the generic bootstrap loader. It includes sample code as well.
/hpg
Could you please point me to that link/page. I am just reading Datasheet now. I have registered to Myinfineon with my company details.
User9888
I can't give you a link, but I can tell you how to get there. First logon to MyInfineon. Next scroll down to the "Library Root" section. Then expand the "AURIX general" category and in here expand the the "Application Notes" category. In here scroll to application note AP32272. Enjoy.
Henk-Piet Glas
hi, I could not see the "Library Root" section. Where is it located? Thanks
@Henk-Piet Glas - I too could not locate the Library Root section. Please help us.
Thank you
vk18434
I can't find the Library Root section either. Any suggestions?
Thanks!
You will need to signup to myinfineon first. Once you have details. Send an email to AURIX@infineon.com from your registered company ID with myinfineon login name.
For ex :
send email to AURIX@infineon.com
In the subject mention : activation of myinfieon login.
Body of email :
My Infineon login is vk18434 (You can type your user name here)
Once its activated, you can access all the application notes, code samples etc.
vk18434
