Jan 18, 2021
05:02 AM
Jan 18, 2021
05:02 AM
I am using Application Kit TC2x7 v1.1 with TC277 processor. At one point I've programmed BootModeHeader 0 with values 0xb3590048 value for BMI which represents Generic Bootstrap Loader.
And now I am locked out of device and cannot acces it thru Infineon Memtool nor Aurix IDE.
In this thread https://www.infineonforums.com/threads/5933-TC277-JTAG-locked a person named MoD said that it is possible to unlock it with Memtool. How can I unlock it to be able to program a BMHD0 with values for Internal Flash Start?
05:52 AM
Jan 18, 2021
05:52 AM
I've tried creating a Minimonitor Target Interface with ASC bootstrap loader at 9600 Bit/s but still no luck connecting to device.
Jan 19, 2021
03:38 AM
Jan 19, 2021
03:38 AM
Hi
if u are using Memtool. u should change ur target to -> TriBoard with TC275/TC277 ?-Step (BSL/ASC)
after that in setup, u should ensure u are using the correct COM port which is connected to the kit.
Jan 20, 2021
01:06 AM
Jan 20, 2021
01:06 AM
Thank you that worked!
