- Email to a Friend
I am using an AURIX TC277 TFT devkit, and trying to write to a serial port. According to the user manual, a COM port should be created when I connect the device to my PC, but that is not happening. The DAS JDS COM and DAS JDS Debug both show up under USB devices, but the COM port is not being created:
Any ideas on how to resolve this?
- Email to a Friend
Reinstall is not needed/helpful.
Connect the board
In the Device Manager:
Select Properties on Infineon DAS JDS COM with right mouse
Select Tab Advanced and mark 'Load VCP' as active
Save the settings
Remove the board from USB and reconnect
Now the COM port should be installed
- Email to a Friend
Hi tannerhunsucket,
Please check above link of my screenshot.
Please try to uninstall DAS and reinstall. The USB port should be configure to COM port with proper drivers.
dw
- Email to a Friend
Connect the board
Save the settings
- Email to a Friend
Thank you, this resolved my issue!
